Hassio started crashing?
Yesturday I noiticed that hassio running on my pi3 became unavailable and the only way I could get it up and running again was to power cycle the pi. Overnight it was intermittent, I could use google mini voice commands to turn off lights sometimes but not at other times.
This afternoon I thought maybe I should update so updated to 0.100.2 but within half an hour it went down again.
I tried a hassio ho restart and although lovelace loads, menu items like ‘hassio’ doesn’t load, after a power cycle all is well for a short period.
Are you using an sd card? Have you checked the dmesg output (type dmesg in a terminal), if your sd card is having write issues, errors should be printed there.
thanks, yes using an sd card, all I could see in the dmesg output relating to sd are the following lines:
sdhci: Secure Digital Host Controller Interface driver
[    0.768882] sdhci: Copyright(c) Pierre Ossman
[    0.771338] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
[    0.773598] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    0.774616] sdhci-pltfm: SDHCI platform and OF driver helper
but I could be wrong
