Hello guys home assistant has stopped working.
Running on Raspberry PI OS
This is the log when I try to run sudo hassio-supervisor
pi@raspberrypi:~ $ sudo hassio-supervisor [s6-init] making user provided files available at /var/run/s6/etc…exited 0. [s6-init] ensuring user provided files have correct perms…exited 0. [fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] udev.sh: executing…
[14:13:19] INFO: Setup udev backend inside container
[14:13:19] INFO: Update udev information
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[14:13:20] INFO: Starting local supervisor watchdog…
Fatal Python error: init_sys_streams: can’t initialize sys standard streams
Python runtime state: core initialized
AttributeError: module ‘io’ has no attribute ‘OpenWrapper’
Current thread 0x004f1030 (most recent call first):
[cont-finish.d] executing container finish scripts…
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
Thank you in advance
