I have hassio installed on a Raspberry Pi, and everything has been going smoothly for some months. Lately, however, I cannot
- access hassio.local
- access the webserver via ip
- ping the ip
- ssh to the pi
A hard reboot does not fix this. However, all of the automations are still running, which is a bit mystifying. Any suggestions?
Check your router to see what IP address the Hassio has - it’s probably changed if you didn’t lock that device to the iPhone address.
I experience the exact same. 24 hours ago it worked fine - I did no updates/upgrades/changes.
HA is not showing up in the browser or APP. The IP adress is fixed and it pops up during a network scan.
I can connect to the fileshares backup, config etc…but not via browser…
I would also like to know what could be done?
I have checked for the new address and cannot access it in a browser or ping it.
I ended up refreshing and restoring the backup from yesterday - works now, but still strange…
