Found a couple of threads re: the same problem I am experiencing but have been unable to solve. Running HA in docker on Raspbian Lite on a rpi4. Rebooted the system this morning and supervisor isn’t coming back up.
Below is what I am seeing in the docker logs for hassio-supervisor. Image info:
io.hass.version=214
20-04-04 19:38:23 INFO (MainThread) [supervisor.discovery] Load 1 messages
File "/usr/local/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/usr/local/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "/usr/src/supervisor/supervisor/__main__.py", line 47, in <module>
loop.run_until_complete(coresys.core.setup())
File "uvloop/loop.pyx", line 1456, in uvloop.loop.Loop.run_until_complete
File "/usr/src/supervisor/supervisor/core.py", line 79, in setup
await self.sys_ingress.load()
File "/usr/src/supervisor/supervisor/ingress.py", line 56, in load
self._cleanup_sessions()
File "/usr/src/supervisor/supervisor/ingress.py", line 74, in _cleanup_sessions
valid_dt = utc_from_timestamp(valid)
File "/usr/src/supervisor/supervisor/utils/dt.py", line 87, in utc_from_timestamp
return UTC.localize(datetime.utcfromtimestamp(timestamp))
OverflowError: timestamp out of range for platform time_t
Never did. I ended up using a backup and completely re-installing. After spending two full days trying to troubleshoot it was easier and took me 2 hrs tops to get everything back up and running.
Anyone have any ideas? I just went from 17 to 19 and it’s back
20-04-23 03:32:57 INFO (MainThread) [supervisor.discovery] Load 1 messages
File "/usr/src/supervisor/supervisor/core.py", line 77, in setup
Got exactly the same issue. Spend some time to investigate, but found the exact reason of the issue.
Sometimes, for whatever reason, it is possible that incorrect session data may appear in /usr/share/hassio/ingress.json. As far as I understand, session data is being stored in this file.
ingress.py doesn’t validate data from this json file, and passes timestamp to utility function, where bad timestamp causes error.
Solution is to remove all or most sessions from /usr/share/hassio/ingress.json file.
I’m going to propose fix, validating sessions data in ingress.py to avoid future issues with this.
