So I’ve been having an issue which has been going on for the last six months or so. Every once in a while (usually every few weeks), all of my automations will just stop working. I go to look into what is going on and home assistant is running and accessible, but none of the plugins nor the hassio settings are available (I run my automations through nodered). Looking in portainer, everything is running fine except hassio supervisor has shut down. Looking into the container log for hassio supervisor, I get the log below when I try to get the container to restart. The hassio log shows absolutely nothing for the time the hassio supervisor goes down. Portainer itself says the container was shutdown with code 137 which googling shows me is an out-of-memory code. Restarting the container just causes it to shut down again the same way The only solution I have found is to shut down home assistant and completely reinstall it and then hassio supervisor will be fine for a week or two before the problem repeats again. Any thoughts on what could be going on here, or what a solution could be? I’ve been poking around the issue every time it happens, but I’m usually in a rush to try to get things going again as I run a lot of aquarium functions through home assistant and I don’t want things down too long.
20-02-11 03:42:27 INFO (MainThread) [__main__] Initialize Hass.io setup
20-02-11 03:42:27 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 199
20-02-11 03:42:27 INFO (SyncWorker_0) [hassio.docker.interface] Cleanup images: ['homeassistant/amd64-hassio-supervisor:200', 'homeassistant/amd64-hassio-supervisor:latest']
20-02-11 03:42:28 INFO (MainThread) [__main__] Setup HassIO
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
20-02-11 03:42:28 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
20-02-11 03:42:28 INFO (MainThread) [hassio.host.info] Update local host information
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-02-11 03:42:28 INFO (MainThread) [hassio.host.services] Update service information
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-02-11 03:42:28 INFO (MainThread) [hassio.host.network] Update local network DNS information
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-02-11 03:42:28 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
20-02-11 03:42:28 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
20-02-11 03:42:28 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
20-02-11 03:42:28 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 1
20-02-11 03:42:28 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
20-02-11 03:42:28 INFO (SyncWorker_1) [hassio.docker.interface] Restart homeassistant/amd64-hassio-dns
20-02-11 03:42:30 INFO (SyncWorker_3) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.105.2
20-02-11 03:42:30 ERROR (MainThread) [hassio.utils.json] Can't read json from /data/addons/git/8f7a9674/repository.json: [Errno 2] No such file or directory: '/data/addons/git/8f7a9674/repository.json'
20-02-11 03:42:30 WARNING (MainThread) [hassio.store.data] Can't read repository information from /data/addons/git/8f7a9674/repository.json
20-02-11 03:42:30 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
20-02-11 03:42:30 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/cebe7a76 repository
20-02-11 03:42:30 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-02-11 03:42:30 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/8f7a9674 repository
20-02-11 03:42:30 INFO (MainThread) [hassio.store] Load add-ons from store: 63 all - 63 new - 0 remove
20-02-11 03:42:30 INFO (MainThread) [hassio.addons] Found 7 installed add-ons
20-02-11 03:42:30 INFO (SyncWorker_7) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.1
20-02-11 03:42:30 INFO (SyncWorker_5) [hassio.docker.interface] Attach to hassioaddons/aircast-amd64 with version 2.2.2
20-02-11 03:42:30 INFO (SyncWorker_9) [hassio.docker.interface] Attach to homeassistant/amd64-addon-configurator with version 4.2
20-02-11 03:42:30 INFO (SyncWorker_6) [hassio.docker.interface] Attach to sabeechen/hassio-google-drive-backup-amd64 with version 0.100.0
20-02-11 03:42:30 INFO (SyncWorker_12) [hassio.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.14.3
20-02-11 03:42:30 INFO (SyncWorker_0) [hassio.docker.interface] Attach to homeassistant/amd64-addon-check_config with version 3.1
20-02-11 03:42:30 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/node-red-amd64 with version 6.0.4
20-02-11 03:42:30 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-02-11 03:42:30 INFO (MainThread) [hassio.snapshots] Found 5 snapshot files
20-02-11 03:42:30 INFO (MainThread) [hassio.discovery] Load 1 messages
20-02-11 03:42:30 INFO (MainThread) [hassio.ingress] Load 0 ingress session
20-02-11 03:42:30 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 24
20-02-11 03:42:30 INFO (MainThread) [__main__] Run Hass.io
20-02-11 03:42:30 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
20-02-11 03:42:30 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 200
20-02-11 03:42:30 INFO (SyncWorker_19) [hassio.docker.interface] Update image homeassistant/amd64-hassio-supervisor:199 to homeassistant/amd64-hassio-supervisor:200
20-02-11 03:42:30 INFO (SyncWorker_19) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 200.
20-02-11 03:42:34 INFO (MainThread) [__main__] Stopping Hass.io
20-02-11 03:42:34 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2
20-02-11 03:42:34 INFO (MainThread) [hassio.misc.forwarder] Stop DNS forwarding
20-02-11 03:42:34 INFO (MainThread) [hassio.core] Hass.io is down
20-02-11 03:42:34 INFO (MainThread) [__main__] Close Hass.io
20-02-11 03:42:40 INFO (SyncWorker_19) [hassio.docker.interface] Tag image homeassistant/amd64-hassio-supervisor with version 200 as latest
20-02-11 03:42:40 INFO (SyncWorker_19) [hassio.docker.interface] Stop hassio_supervisor application```
