yeah nah im gonna need some help, it just stops? theres no explanation?
its just
off
19-08-17 02:38:38 INFO (MainThread) [hassio.store] Load add-ons from store: 129 all - 129 new - 0 remove,
19-08-17 02:38:38 INFO (MainThread) [hassio.addons] Found 20 installed add-ons,
19-08-17 02:38:38 INFO (SyncWorker_0) [hassio.docker.interface] Attach to sabeechen/hassio-google-drive-backup-amd64 with version 0.98.2,
19-08-17 02:38:38 INFO (SyncWorker_2) [hassio.docker.interface] Attach to bestlibre/amd64-influxdb with version 1.7.4,
19-08-17 02:38:38 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mariadb with version 1.2,
19-08-17 02:38:38 INFO (SyncWorker_14) [hassio.docker.interface] Attach to hassioaddons/aircast-amd64 with version v2.1.0,
19-08-17 02:38:38 INFO (SyncWorker_17) [hassio.docker.interface] Attach to bestlibre/amd64-aria2 with version 0.3,
19-08-17 02:38:38 INFO (SyncWorker_4) [hassio.docker.interface] Attach to hassioaddons/grafana-amd64 with version v2.2.3,
19-08-17 02:38:38 INFO (SyncWorker_1) [hassio.docker.interface] Attach to poeschl/hassio-icantbelieveitsnotvaletudo-amd64 with version 0.2.0,
19-08-17 02:38:38 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/node-red-amd64 with version v4.0.7,
19-08-17 02:38:38 INFO (SyncWorker_8) [hassio.docker.interface] Attach to hassioaddons/traccar-amd64 with version v0.5.2,
19-08-17 02:38:38 INFO (SyncWorker_4) [hassio.docker.interface] Attach to hassioaddons/grocy-amd64 with version v0.3.1,
19-08-17 02:38:38 INFO (SyncWorker_9) [hassio.docker.interface] Attach to homeassistant/amd64-addon-samba with version 8.1,
19-08-17 02:38:38 INFO (SyncWorker_14) [hassio.docker.interface] Attach to hassioaddons/unifi-amd64 with version v0.11.0,
19-08-17 02:38:38 INFO (SyncWorker_17) [hassio.docker.interface] Attach to hassioaddons/nginxproxymanager-amd64 with version v0.2.1,
19-08-17 02:38:38 INFO (SyncWorker_13) [hassio.docker.interface] Attach to hassioaddons/adb-amd64 with version v0.5.1,
19-08-17 02:38:38 INFO (SyncWorker_12) [hassio.docker.interface] Attach to hassioaddons/vscode-amd64 with version v0.6.2,
19-08-17 02:38:38 INFO (SyncWorker_1) [hassio.docker.interface] Attach to hassioaddons/bitwarden-amd64 with version v0.2.1,
19-08-17 02:38:38 INFO (SyncWorker_6) [hassio.docker.interface] Attach to bestlibre/amd64-syncthing with version 1.1.0,
19-08-17 02:38:38 INFO (SyncWorker_15) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 2.0,
19-08-17 02:38:38 INFO (SyncWorker_7) [hassio.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.13.6,
19-08-17 02:38:38 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
19-08-17 02:38:43 INFO (MainThread) [hassio.snapshots] Found 3 snapshot files,
19-08-17 02:38:43 INFO (MainThread) [hassio.discovery] Load 0 messages,
19-08-17 02:38:43 INFO (MainThread) [hassio.ingress] Load 5 ingress session,
19-08-17 02:38:43 INFO (MainThread) [__main__] Run Hass.io,
19-08-17 02:38:43 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons,
19-08-17 02:38:43 INFO (MainThread) [hassio.api] Start API on 172.30.32.2,
19-08-17 02:38:43 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 179,
19-08-17 02:38:43 INFO (SyncWorker_18) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 179.,
19-08-17 02:39:03 INFO (MainThread) [__main__] Initialize Hass.io setup,
19-08-17 02:39:03 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 173,
19-08-17 02:39:03 INFO (MainThread) [__main__] Setup HassIO,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /,
19-08-17 02:39:03 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n',
19-08-17 02:39:03 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc,
19-08-17 02:39:03 INFO (MainThread) [hassio.host.info] Update local host information,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1,
19-08-17 02:39:03 INFO (MainThread) [hassio.host.services] Update service information,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1,
19-08-17 02:39:03 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'},
19-08-17 02:39:03 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service,
19-08-17 02:39:03 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1,
19-08-17 02:39:03 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/intel-nuc-homeassistant with version 0.97.2,
19-08-17 02:39:03 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/kanboard/config.json: required key not provided @ data['arch']. Got None,
19-08-17 02:39:03 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/snapcastserver/config.json: required key not provided @ data['arch']. Got None,
19-08-17 02:39:03 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/nextcloud/config.json: required key not provided @ data['arch']. Got None,
19-08-17 02:39:03 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/mopidy_alpine/config.json: required key not provided @ data['arch']. Got None,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/0d319786 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/243ffc37 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/40817795 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/15ef4d2f repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/53caca22 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/3983e8d8 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/cebe7a76 repository,
19-08-17 02:39:03 INFO (MainThread) [hassio.store] Load add-ons from store: 129 all - 129 new - 0 remove,
19-08-17 02:39:03 INFO (MainThread) [hassio.addons] Found 20 installed add-ons,
19-08-17 02:39:03 INFO (SyncWorker_8) [hassio.docker.interface] Attach to hassioaddons/aircast-amd64 with version v2.1.0,
19-08-17 02:39:03 INFO (SyncWorker_13) [hassio.docker.interface] Attach to bestlibre/amd64-aria2 with version 0.3,
19-08-17 02:39:03 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/bitwarden-amd64 with version v0.2.1,
19-08-17 02:39:03 INFO (SyncWorker_16) [hassio.docker.interface] Attach to hassioaddons/grocy-amd64 with version v0.3.1,
19-08-17 02:39:03 INFO (SyncWorker_17) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 2.0,
19-08-17 02:39:03 INFO (SyncWorker_12) [hassio.docker.interface] Attach to sabeechen/hassio-google-drive-backup-amd64 with version 0.98.2,
19-08-17 02:39:03 INFO (SyncWorker_2) [hassio.docker.interface] Attach to poeschl/hassio-icantbelieveitsnotvaletudo-amd64 with version 0.2.0,
19-08-17 02:39:03 INFO (SyncWorker_1) [hassio.docker.interface] Attach to bestlibre/amd64-syncthing with version 1.1.0,
19-08-17 02:39:03 INFO (SyncWorker_9) [hassio.docker.interface] Attach to hassioaddons/vscode-amd64 with version v0.6.2,
19-08-17 02:39:03 INFO (SyncWorker_10) [hassio.docker.interface] Attach to hassioaddons/node-red-amd64 with version v4.0.7,
19-08-17 02:39:03 INFO (SyncWorker_15) [hassio.docker.interface] Attach to esphome/esphome-hassio-amd64 with version 1.13.6,
19-08-17 02:39:03 INFO (SyncWorker_17) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mariadb with version 1.2,
19-08-17 02:39:03 INFO (SyncWorker_0) [hassio.docker.interface] Attach to hassioaddons/traccar-amd64 with version v0.5.2,
19-08-17 02:39:03 INFO (SyncWorker_6) [hassio.docker.interface] Attach to hassioaddons/nginxproxymanager-amd64 with version v0.2.1,
19-08-17 02:39:03 INFO (SyncWorker_2) [hassio.docker.interface] Attach to hassioaddons/adb-amd64 with version v0.5.1,
19-08-17 02:39:03 INFO (SyncWorker_12) [hassio.docker.interface] Attach to bestlibre/amd64-influxdb with version 1.7.4,
19-08-17 02:39:03 INFO (SyncWorker_14) [hassio.docker.interface] Attach to hassioaddons/unifi-amd64 with version v0.11.0,
19-08-17 02:39:03 INFO (SyncWorker_8) [hassio.docker.interface] Attach to homeassistant/amd64-addon-samba with version 8.1,
19-08-17 02:39:03 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/grafana-amd64 with version v2.2.3,
19-08-17 02:39:03 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json,
19-08-17 02:39:04 INFO (MainThread) [hassio.snapshots] Found 3 snapshot files,
19-08-17 02:39:04 INFO (MainThread) [hassio.discovery] Load 0 messages,
19-08-17 02:39:04 INFO (MainThread) [hassio.ingress] Load 5 ingress session,
19-08-17 02:39:04 INFO (MainThread) [__main__] Run Hass.io,
19-08-17 02:39:04 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons,
19-08-17 02:39:04 INFO (MainThread) [hassio.api] Start API on 172.30.32.2,
19-08-17 02:39:04 INFO (MainThread) [hassio.supervisor] Update Supervisor to version 179,
19-08-17 02:39:04 INFO (SyncWorker_19) [hassio.docker.interface] Pull image homeassistant/amd64-hassio-supervisor tag 179.,
19-08-17 02:39:06 INFO (MainThread) [__main__] Stopping Hass.io,
19-08-17 02:39:06 INFO (MainThread) [hassio.api] Stop API on 172.30.32.2,
19-08-17 02:39:06 INFO (MainThread) [hassio.misc.dns] Stop DNS forwarding,
19-08-17 02:39:06 INFO (MainThread) [hassio.core] Hass.io is down,
19-08-17 02:39:06 INFO (MainThread) [__main__] Close Hass.io,
because the supervisor wont start, neither will half my addons, including nginx, so i cant access remotely at the moment ![:confused: :confused:](https://community.home-assistant.io/images/emoji/twitter/confused.png?v=9)
