[hassio.supervisor] Supervisor does not run in Privileged mode
In my Hassio log I found this text:
ERROR (MainThread) [hassio.supervisor] Supervisor does not run in Privileged mode. Hassio runs with limited functionality!
What this mean?
Same happened to me.
I don’t know if it’s related but now i cant start my deconz addon because it doesn’t find the conbee II anymore
Same thing, and I think it’s related to my inability to update add-ons because I also see “19-10-09 00:57:06 WARNING (MainThread) [hassio.dns] Can’t write local resolv: [Errno 13] Permission denied: ‘/etc/resolv.conf’”
I’m currently at 0.96.4 of HomeAssistant
Same thing here, no solution?
same here, 0.100.1
I just started getting this today after upgrading from .99 to .100.2
I was on HassOS 2.8. I updated to HassOS 2.12 but it made no difference.
Same for me I am on 102
Same here.
Hass.io supervisor
|Version|189|
|Latest version|189|
Host system
|Hostname|hassio|
|System|HassOS 2.10|
|Deployment|production|
System log
starting version 3.2.8
19-10-17 18:27:58 INFO (MainThread) [main] Initialize Hass.io setup
19-10-17 18:27:59 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/armhf-hassio-supervisor with version 189
19-10-17 18:27:59 ERROR (MainThread) [hassio.supervisor] Supervisor does not run in Privileged mode. Hassio runs with limited functionality!
Getting this also. 102
Not so much a solution as a workaround, but saving the config directory on my PC, installing hassio from scratch, and then copying the config directory to the new install worked without issue and I have been able to move on.
Has anyone reported this as an issue? I have the same problem.
I’ve just run into the same issue and had a quick look on github and can’t see any issues logged. Did you get yours sorted?
Nope, happened last night again.
Did someone find a solution?
I think it gives DNS issues as well.
I’m seeing this same error, although not currently causing me any issues.
Has anyone tried changing the supervisor docker container to run with --privileged?
Seems like running supervisor docker with --privileged is solving this issue.
The change has been applied to https://raw.githubusercontent.com/home-assistant/hassio-installer/master/hassio_install.sh also. You can see --privileged inside.
Rerunning this script should solve this issue.
how does the script restart?
explanation for fools please
Is this something I can do with Hassio? Where?
This appears to be stopping me from upgrading.
I’m having the same issue:
WARNING (MainThread) [hassio.dns] Can't write local resolv: [Errno 13] Permission denied: '/etc/resolv.conf'
WARNING (MainThread) [hassio.dns] Ignore invalid DNS Server: dns://2a02:1205:5008:afe0:asd3:f7ff:faca:c1c7
I’m running HassOS3.7. As far as i understood this supervisor should be running in a docker container right? But when i connect to hassio over ssh i can’t seem to find any docker installation. Where should this be located?
did we find a resolution to this? it happening to me now :frowning: 103.0
