Hassio tab is missing
When Home Assistant restarts I no longer see the Hass.io Supervisor menu.
I also get the following in the log:
2020-04-16 15:07:34 ERROR (MainThread) [homeassistant.components.hassio] Missing HASSIO environment variable.
2020-04-16 15:07:34 ERROR (MainThread) [homeassistant.setup] Setup failed for hassio: Integration failed to initialize.
Do you have either of these in your configuration.yaml file?
default_config:
Or
hassio:
Did you recently reinstall?
I did have trouble with HomeAssostant not starting at all. So I have updated some of my Docker containers.
I have the following
hassio:
That would have been some relevant information to include.
