Logger: homeassistant.components.mqtt.entity
Bron: components/mqtt/entity.py:156
integratie: MQTT (documentatie, problemen)
Eerst voorgekomen: 09:29:33 (29 gebeurtenissen)
Laatst gelogd: 09:30:07
Error ‘The unit of measurement VA
is not valid together with device class power
’ when processing MQTT discovery message topic: ‘homeassistant/sensor/2CFAF8_ENERGY_ApparentPower_1/config’, message: ‘{‘availability_topic’: ‘tele/Rolluik_keuken/LWT’, ‘payload_available’: ‘Online’, ‘payload_not_available’: ‘Offline’, ‘device’: {‘identifiers’: [‘2CFAF8’]}, ‘unique_id’: ‘2CFAF8_ENERGY_ApparentPower_1’, ‘name’: ‘Rolluik Keuken ENERGY ApparentPower 1’, ‘force_update’: True, ‘state_topic’: ‘tele/Rolluik_keuken/SENSOR’, ‘unit_of_measurement’: ‘VA’, ‘value_template’: “{{value_json[‘ENERGY’][‘ApparentPower’][0]}}”, ‘device_class’: ‘power’}’
’ when processing MQTT discovery message topic: ‘homeassistant/sensor/2CFAF8_ENERGY_ApparentPower_2/config’, message: ‘{‘availability_topic’: ‘tele/Rolluik_keuken/LWT’, ‘payload_available’: ‘Online’, ‘payload_not_available’: ‘Offline’, ‘device’: {‘identifiers’: [‘2CFAF8’]}, ‘unique_id’: ‘2CFAF8_ENERGY_ApparentPower_2’, ‘name’: ‘Rolluik Keuken ENERGY ApparentPower 2’, ‘force_update’: True, ‘state_topic’: ‘tele/Rolluik_keuken/SENSOR’, ‘unit_of_measurement’: ‘VA’, ‘value_template’: “{{value_json[‘ENERGY’][‘ApparentPower’][1]}}”, ‘device_class’: ‘power’}’
Error ‘The unit of measurement VAr
’ when processing MQTT discovery message topic: ‘homeassistant/sensor/2CFAF8_ENERGY_ReactivePower_1/config’, message: ‘{‘availability_topic’: ‘tele/Rolluik_keuken/LWT’, ‘payload_available’: ‘Online’, ‘payload_not_available’: ‘Offline’, ‘device’: {‘identifiers’: [‘2CFAF8’]}, ‘unique_id’: ‘2CFAF8_ENERGY_ReactivePower_1’, ‘name’: ‘Rolluik Keuken ENERGY ReactivePower 1’, ‘force_update’: True, ‘state_topic’: ‘tele/Rolluik_keuken/SENSOR’, ‘unit_of_measurement’: ‘VAr’, ‘value_template’: “{{value_json[‘ENERGY’][‘ReactivePower’][0]}}”, ‘device_class’: ‘power’}’
’ when processing MQTT discovery message topic: ‘homeassistant/sensor/2CFAF8_ENERGY_ReactivePower_2/config’, message: ‘{‘availability_topic’: ‘tele/Rolluik_keuken/LWT’, ‘payload_available’: ‘Online’, ‘payload_not_available’: ‘Offline’, ‘device’: {‘identifiers’: [‘2CFAF8’]}, ‘unique_id’: ‘2CFAF8_ENERGY_ReactivePower_2’, ‘name’: ‘Rolluik Keuken ENERGY ReactivePower 2’, ‘force_update’: True, ‘state_topic’: ‘tele/Rolluik_keuken/SENSOR’, ‘unit_of_measurement’: ‘VAr’, ‘value_template’: “{{value_json[‘ENERGY’][‘ReactivePower’][1]}}”, ‘device_class’: ‘power’}’
Error ‘The unit of measurement %
is not valid together with device class temperature
’ when processing MQTT discovery message topic: ‘homeassistant/sensor/ebusd_bai_ModulationTempDesired_value/config’, message: '{‘unique_id’: ‘ebusd_bai_ModulationTempDesired_value’, ‘device’: {‘identifiers’: ‘ebusd_bai’, ‘manufacturer’: ‘ebusd.eu’, ‘via_device’: ‘ebusd’, ‘sw_version’: ‘25.1’, ‘suggested_area’: ‘Heating’, ‘name’: ‘ebusd bai’}, ‘value_template’: ‘{{value_json[“value”].value}}’, ‘state_topic’: ‘ebusd/bai/ModulationTempDesired’, ‘unit_of_measurement’: ‘%’, ‘state_class’: ‘measurement’, ‘device_class’: ‘temperature’, ‘name’: 'ModulationTempDesired ‘}’
