Paul-dH
(Paul-dH)
September 29, 2018, 10:06pm
1
Hi all,
I’ve installed https://github.com/jkeljo/hassio-addons/tree/master/ozwcp and of course I started reading the manual after the start of the add-on. Whoops…
I don’t have the SSH add-on running and I can’t access the UI.
I do have a lot of bad experience with Raspberry’s and corrupted SD-cards, so I don’t like the idea to pull the plug out.
Any advice here?
Thanks!
Paul-dH
(Paul-dH)
September 29, 2018, 10:33pm
2
I’ve found another way to safely reset the Pi:
Raspberry Pi 2 Reset Button: This is a quick Instructable, showing how I added a reset button to my Raspberry Pi 2.The Pi 2 has two hearder pin holes next to the display socket, which is marked "RUN". When this pins are shorted together, the...
There is a run header on the board, short it with a paperclip and after the release the Pi will reboot. This was the only option after a “lockout” that should’nt brick your SD-Card…
Tomorrow I’ll solder a reset button on that header
