20-02-06 16:21:07 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocke t API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
Got it working in the end, observed the restart after installing 0.105.2 getting stuck at udevd[10]: Starting eudev on the console so I removed the Google Cast integration as suggested here https://github.com/home-assistant/supervisor/issues/859 and was able to complete the first boot after the update.
with the “Check home assistant” add-on do you have this error?
Log
starting version 3.2.8
[16:37:40] INFO: Don't worry, this temporary installation is not overwriting your current one.
[16:37:40] INFO: Installing Home Assistant: latest...
[16:37:40] INFO: Please be patient, this might take a few minutes...
Fatal Python error: initsite: Failed to import the site module
File "/usr/local/lib/python3.7/site.py", line 73, in <module>
import os
File "/usr/local/lib/python3.7/os.py", line 27, in <module>
import stat as st
ModuleNotFoundError: No module named 'stat'
[16:37:40] ERROR: An error occurred while installing Home Assistant:
have you tried to create a new env from scratch? maybe would be good to start this way and start activating items step by step. I had to do that when I upgraded to 0.104
the good thing, I was able to clean up a lot my configuration
