I have tried a few times with command line and UI with the same results. Not much in the way of logs either.
This is all I get:
This is all I get:
I don’t seem to be alone:
this update broke my entire system, had to do a full reset with a sdcard re flash. luckily I had a back up, but SSL is totally broken. Please add a Revert option for the updates. or at least let us install other versions on Hass.io
Same situation and I’m getting the exact same error. Haven’t found a resolution yet.
It give a error like this, if the SD card is to small to fetch the update
I’ve chased that down but I don’t see how space is an issue…mapping the SMB \share directory (e.g. \hassio\share) from windows shows space free @ 9.69GB. SSH’ing in and running df -h shows the same…
core-ssh:/# df -h
Filesystem Size Used Available Use% Mounted on
none 13.3G 2.9G 9.7G 23% /
tmpfs 486.1M 36.0K 486.1M 0% /dev
tmpfs 486.1M 0 486.1M 0% /sys/fs/cgroup
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /data
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /config
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /ssl
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /addons
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /backup
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /share
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /etc/resolv.conf
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /etc/hostname
/dev/mmcblk0p6 13.3G 2.9G 9.7G 23% /etc/hosts
shm 64.0M 0 64.0M 0% /dev/shm
tmpfs 486.1M 36.0K 486.1M 0% /proc/timer_list
tmpfs 486.1M 36.0K 486.1M 0% /proc/timer_stats
tmpfs 486.1M 36.0K 486.1M 0% /proc/sched_debug
tmpfs 486.1M 0 486.1M 0% /sys/firmware
how did you free some space?
