This is very strange. After updating to 83.2, whenever I unlock/lock my Schlage zwave lock from HA, lock status doesn’t change. If I manually turn the knob, it updates. Restoring 83.1 snapshot corrects the issue.
Looks like I am having the same issue. Did you find a resolution?
It’s a bug. I believe it’s been fixed and will be released in the next update. If you poke around on Github you might find the conversation.
I found it. There is a custom_component that fixes the issue until the next release.
Unfortunately the update didn’t fix the problem for me. How about you?
I didn’t see anything in the release notes for the schlage lock. I didn’t even try without the custom component.
I cant find the issue with the custom component. Do you know the id #?
Thanks! I put the zwave.py referenced in a custom component directory and it worked!
