[hassio.utils.gdbus] DBus return error: b'Error:?
18-07-06 20:46:43 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-07-06 20:46:43 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-07-06 20:46:43 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-07-06 20:46:44 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-07-06 20:46:44 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-07-06 20:46:44 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b’Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n’
18-07-06 20:46:44 WARNING (MainThread) [hassio.dbus.rauc] Can’t connect to rauc
18-07-06 20:46:44 INFO (MainThread) [hassio.host.info] Update local host information
18-07-06 20:46:44 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
I believe it started after updating to the latest version, could be a coincidence. Couldn’t find info about it online.
Hassio is working fine but everything has quite the bit of latency (this alternatively could be due to bluetooth being enabled)
Hi Majidah, I have the same problem. Did you solve it?
I have not solved it.
I’m having the same issue.
18-07-09 20:57:29 INFO (MainThread) [__main__] Initialize Hassio setup
18-07-09 20:57:29 INFO (MainThread) [__main__] Setup HassIO
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.systemd1 on /org/freedesktop/systemd1
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Introspect org.freedesktop.hostname1 on /org/freedesktop/hostname1
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Introspect de.pengutronix.rauc on /
18-07-09 20:57:29 ERROR (MainThread) [hassio.utils.gdbus] DBus return error: b'Error: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name de.pengutronix.rauc was not provided by any .service files\n'
18-07-09 20:57:29 WARNING (MainThread) [hassio.dbus.rauc] Can't connect to rauc
18-07-09 20:57:29 INFO (MainThread) [hassio.host.info] Update local host information
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
18-07-09 20:57:29 INFO (MainThread) [hassio.host.services] Update service information
18-07-09 20:57:29 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
18-07-09 20:57:30 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
18-07-09 20:57:30 INFO (MainThread) [hassio.host.apparmor] AppArmor is not enabled on Host
18-07-09 20:57:30 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to supervisor homeassistant/armhf-hassio-supervisor with version 115
18-07-09 20:57:30 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/raspberrypi3-homeassistant with version 0.73.1
18-07-09 20:57:30 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/git/a0d7b954 repository
18-07-09 20:57:30 INFO (MainThread) [hassio.addons.git] Load addon /data/addons/core repository
18-07-09 20:57:31 INFO (MainThread) [hassio.addons] Load addons: 41 all - 41 new - 0 remove
18-07-09 20:57:31 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-cec_scan with version 0.2
18-07-09 20:57:31 INFO (SyncWorker_4) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-letsencrypt with version 2.2
18-07-09 20:57:31 INFO (SyncWorker_6) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-google_assistant with version 2.1
18-07-09 20:57:31 INFO (SyncWorker_1) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-samba with version 4.1
18-07-09 20:57:31 INFO (SyncWorker_2) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-configurator with version 0.4
18-07-09 20:57:31 INFO (SyncWorker_10) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-mosquitto with version 2.0
18-07-09 20:57:31 INFO (SyncWorker_3) [hassio.docker.interface] Attach to image homeassistant/armhf-addon-ssh with version 3.7
18-07-09 20:57:31 INFO (MainThread) [hassio.updater] Fetch update data from https://s3.amazonaws.com/hassio-version/stable.json
18-07-09 20:57:31 INFO (MainThread) [hassio.snapshots] Found 0 snapshot files
18-07-09 20:57:31 INFO (MainThread) [__main__] Run HassIO
18-07-09 20:57:31 INFO (MainThread) [hassio.misc.dns] Start DNS port forwarding for host add-ons
18-07-09 20:57:31 INFO (MainThread) [hassio.core] Ignore Hass.io auto updates on dev channel
18-07-09 20:57:31 INFO (MainThread) [hassio.core] Start API on 172.30.32.2
18-07-09 20:57:31 INFO (MainThread) [hassio.addons] Startup initialize run 0 addons
18-07-09 20:57:31 INFO (MainThread) [hassio.addons] Startup system run 1 addons
18-07-09 20:57:34 INFO (SyncWorker_7) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-mosquitto with version 2.0
18-07-09 20:57:39 INFO (MainThread) [hassio.addons] Startup services run 2 addons
18-07-09 20:57:40 INFO (SyncWorker_8) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-samba with version 4.1
18-07-09 20:57:41 INFO (SyncWorker_9) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-ssh with version 3.7
18-07-09 20:58:03 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.73.1
18-07-09 20:59:03 INFO (MainThread) [hassio.homeassistant] Detect a running Home-Assistant instance
18-07-09 20:59:03 INFO (MainThread) [hassio.addons] Startup application run 2 addons
18-07-09 20:59:03 ERROR (MainThread) [hassio.addons.addon] Addon core_google_assistant have wrong options: Missing required option 'project_id'. Got {'client_secrets': 'google_assistant.json', 'project_id': None, 'model_id': None}
18-07-09 20:59:05 INFO (SyncWorker_9) [hassio.docker.addon] Start docker addon homeassistant/armhf-addon-configurator with version 0.4
18-07-09 20:59:10 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
18-07-09 20:59:10 INFO (MainThread) [hassio.core] Hass.io is up and running
Same here:
I am having the same issue… thoughts?
It seems to be reported on github, and from the information there I understand that this error can be ignored if you are not running HassOS but a generic linux
i am also having this same error in my home assistant server ,
is there any solution ?
