both of the images: Raspberry Pi 3 Model B and B+ 32bit (recommended) and Raspberry Pi 3 Model B and B+ 64bit
waiting more than 3 hours and not just 20 minutes after first installation
When I insert the SD card to my raspberry pi I see a couple of booting activities cause the green light flashes a couple of times but then it ends up that the red light is steadily on.
For me it’s strange that I see hassio in my network but can’t access the webgui.
Don’t bother with 64 bit image.
The first thing you should see is the “setting up” page at ip_address:8123 and this should appear within minutes of booting the pi.
You can connect a keyboard and monitor directly to the pi to login as “root”. You will arrive at the Hassio CLI. From there, you can type “login” and continue to the host os. From the host console you can check network settings using nmcli, and check the time/date with date.
When you are at the Hassio cli (you’ll see a hassio > prompt), you can type “login” and continue to the host os where you’ll see a # prompt. That’s where you can use nmcli.
You login as root. There is no password. When you reach the Hassio cli you type “login” and hit enter to get to the host console where you can use nmcli.
Im not able to login to host while ussing ssh to connect to hassio. The default prompt i see js core-ssh:~# and if i type login here it doesn’t let me in.
Is it something only available when connected directly to the rpi and not in headless mode?
Same problem here. After restart I can’t reach the home assistant via IP or host name.
But it is reachable via the remote access (nabu casa / home assistant cloud).
Any suggestions?
