HASSIO VS HA on raspbian
I was using for long time hassbian , as it is not maintained anymore i just wonder if i should move to HASSIO,
I tried it before and had issues to define the USB ports, as they may randomly change
  1. As i am using 2 USB to RS 485 converters , i need to define USB port by-ID and not by USB port( it may change) , is there any solution to do same with Hassio?
  2. As HASSIO is maintained , any suggestion should i move to hassio or keep raspbian ?( assuming 2 modbus converters are used)?
