Hassio wifi setup
Thanks au190. We should find a way to get this included in the official documentation, or at least get a sticky here in the forums. I’d wasted several hours trying to get my Pi to talk my network over wifi before I found these instructions.
Thanks! A question @au190… that procedure works also if I have already installed and configured hass.io? Because I’m trying your stuff, rebooting the RPI with the USB plugged in with the file and all that. And it’s not getting the wifi to work.
Can you help me? thanks
Same boat… hassio installed, I want wifi…
I was struggling as you, at the end I followed the instructions on this video and finally it work! I´m on a raspberry pi3b+, HA 0.74.2 64bits, HassOS 1.7
Wifi Hassio
Hope this also work for you
I’ve documented a guide here with the Wifi approach under step 5.
thanks your instructions are really well done!
Im having the same issue and have tried usb stick and directly editing the sd card…anyone have any successs?
Try renaming the text file “my-network” into “system-connections”. It works for me.
