Hassio + with EQ3 Bluetooth Smart Thermostats
And any news?
No, still waiting. In the meantime I have just gone with Tasmota with bluetooth on ESP32.
Find just this in my logs:
Logger: homeassistant.components.climate
Source: components/eq3btsmart/climate.py:219
Integration: Klima (documentation, issues)
First occurred: 19:33:57 (2 occurrences)
Last logged: 19:33:57
eq3btsmart: Error on device update!
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 477, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 702, in async_device_update
    await task
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/eq3btsmart/climate.py", line 219, in update
    self._thermostat.update()
  File "/usr/local/lib/python3.10/site-packages/eq3bt/eq3btsmart.py", line 217, in update
    self._conn.make_request(PROP_WRITE_HANDLE, value)
  File "/usr/local/lib/python3.10/site-packages/eq3bt/bleakconnection.py", line 106, in make_request
    with self:
  File "/usr/local/lib/python3.10/site-packages/eq3bt/bleakconnection.py", line 51, in __enter__
    self._loop.run_until_complete(self._conn.connect())
  File "/usr/local/lib/python3.10/asyncio/base_events.py", line 646, in run_until_complete
    return future.result()
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/client.py", line 107, in connect
    device = await BleakScannerBlueZDBus.find_device_by_address(
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/scanner.py", line 221, in find_device_by_address
    return await cls.find_device_by_filter(
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/scanner.py", line 250, in find_device_by_filter
    async with cls(detection_callback=apply_filter, **kwargs):
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/scanner.py", line 96, in __aenter__
    await self.start()
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/scanner.py", line 137, in start
    self._stop = await manager.active_scan(
  File "/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/manager.py", line 384, in active_scan
    reply = await self._bus.call(
  File "/usr/local/lib/python3.10/site-packages/dbus_next/aio/message_bus.py", line 305, in call
    await future
RuntimeError: Task <Task pending name='Task-6064' coro=<BleakClientBlueZDBus.connect() running at /usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/client.py:107> cb=[_run_until_complete_cb() at /usr/local/lib/python3.10/asyncio/base_events.py:184]> got Future <Future pending> attached to a different loop
Thats wrong yaml syntax. If its indented it needs to be indented 2 spaces, not 4 or tab.
Using vscode editor it shows you all your yaml errors as soon as you type them.
What do you mean where is a wrong syntax? And do you use this integration?
