Hassio won't start
i’m running Hassio 0.91 on a Pi 3 on an SD card.
Everything was working great till i decided to delete the MQTT from hassio integration.
now Hassio won’t start. Usually when this happens i look in the log through the samba server and fix the error but this time there was no response. ping to the wifi IP also didn’t work.
I manged to mount the sd card on my win laptop and i see all the logs but the home assistant log has nothing from after the restart.
I don’t have a full backup so i prefer to fix the issue.
i already got an SSD drive that i wanted to move everything to but first I want to start from the SD card.
how can i get a more low leve log file?
can i some how copy from the SD the files to a fresh install manually?
Thanks!
Windows can’t read the partitions, but if you have access to a Linux system, or VM you can mount the partitions and copy off what you need.
i managed to read the partitions using a tool called diskinternals linux reader. i see the docker folder resin-data…
