I have completed the setup of my homeassistant server. I used the hass.io image and mhave added the appropriate config to my configuration file:
zwave:
usb_path: /dev/ttyACM0
The zwave component shows up in the web interface. It appears as if it is read only. I can see the states of all of my zwave devices. When I turn a switch on, that change is reflected in the web gui. However, when I attempt to turn a switch on or off via homeassistant, the switch toggles for a moment, and then goes back to its original state. Any suggestions?
Unless you have a Zwave switch with “instant feedback” (my term not the manufacturer’s term) you will need to enable polling to get state updates in a timely manner. See the docs. https://home-assistant.io/docs/z-wave
I have 5 total devices on my network. A zwave stick, a range extender, two dimmers, and one switch. The statuses in the developer tools matches the attached screenshot.
