Hi all,
I’m trying HassOS on my shining new Raspi4B.
Swapping the same HassOS SD (HA 0.98.0) on a 2GB and a 4GB models, both the systemmonitor sensor and the free ssh command gives the same amount of free RAM.
After updating from yesterday’s 0.97.2 to 0.98.0, at 11 AM I swapped the HassOS SD:
So that means @PieBru must have two pi4s and is swapping between the 2GB and a 4GB models. If so, and he’s using the pi 4 image, I have no answer to his question.
Yes @tom_l , I did not use any 3B, sorry if I didn’t explain clearly.
Yesterday I eched the latest PI4 HassOS version, the “recommended” Raspberry Pi 4 Model B 32bit image, freshly downloaded yesterday afternoon, on a single16 GB SD, which showed still having 0.97.2 onboard.
I used this SD on a PI4 2GB, which showed 950MB RAM total, both using ssh free and systemmonitor sensor.
Today I updated this SD to the 0.98.0, meanwhile released overnight (Italy time), and inserted this SD on a PI4 4GB.
On the PI4 4GB free shows the same RAM amount: 950MB, thus this post.
On the PI4 4GB, even cat /proc/meminfo executed in a HassOS ssh session coherently shows MemTotal: 945036kB
BTW with Arch, Raspbian and other 32bit OSs, the two above mentioned PI4 show the correct RAM amount: 2GB the first PI4 and 4GB the second PI4.
Is the 1GB a HassOS or a docker limit?
