I recently bought an Intel NUC7i3BNH with a 256gb 2.5 inch SATA SSD to run HA.
I was able to install ProxMox with no issues. I also had previously installed Ubuntu on this machine without issues. I have disabled secure boot and upgraded the BIOS to the most recent version.
I am able to successfully create (at least at first) a HassOS VM on Proxmox via the Whiskerz script (https://github.com/whiskerz007/proxmox_hassos_install).
If I reboot the machine by using the web interface->Supervisor->System->Host System-> Reboot, the system becomes more and more corrupted with each successive reboot, to the point where it will no longer boot after roughly 3 reboots. This has happened about five times in a row (removing the VM and starting from scratch each time), and even across reinstalls of Proxmox. In the following description, each time I say “reboot”, I mean the process described above via the web interface.
The most recent time I created a VM, I noticed after the first reboot several SQUASHFS errors:
SQUASHFS error: Unable to read data cache entry [bc8bac]
SQUASHFS error: Unable to read page, block bc8bac, size 10060.
It did boot though, and the next time I rebooted, I noticed EXT4-fs errors:
EXT4-fs error (device sda8): ext4_lookup:1591: inode #148747: comm python3
Again it booted despite the errors (though it usually takes longer with the errors). The next time I tried to reboot, I ended up at the four-option boot screen. Autoboot does not work, but I was able to progress the boot attempt by selecting Boot System 0. Then a bunch of python segfault errors occur. I am able to login as root but the web interface does not go up, even after an extended period of time.
I have also tried this on the bare metal, and I think something similar is happening, though I am less able to monitor the errors messages as I have not had success loading the CONFIG/network/my-network file and I do not have a monitor near where I can plug into my router via ethernet. But after a few boots which take longer and longer, I end up just seeing the four-option boot screen and am not able to reboot without selecting a boot option after a few reboots.
I have tried this with a few different cache settings on Proxmox (no cache, write through, and direct sync) with no clear improvement. I fiddled a bit with other virtual hardware settings, but don’t really have a good idea of what settings are likely to be most fruitful, and the possible combinations are endless. I have scoured the internet for others with similar issues, and saw a few similar reports but none that had a clear resolution.
I have also tried installing on the bare metal as I mentioned above, as well as using the qcow2 image on Proxmox (Supervised Install on Proxmox)
I am about ready to give up on HassOS and just switch to HA core on a linux desktop, but would prefer to get HassOS working if possible. I can’t commit to using HassOS unless I can reboot it stably a few times, otherwise I feel like it is a ticking time bomb that is sure to die after a few power outages. Improved stability is the whole reason I am trying to upgrade from a Pi4 to a NUC.
Thank you in advance for any advice you might be able to provide.
