The BT in my RPI3 running 4.14 seems not to be working (at least I have lost the connection of all my Xiaomi LBTE devices - which used to work fine using this integration).
It started happening yesterday, I believe that at the same time that following this post and running:
nmcli radio wifi off
I disconnected the wifi. I have tried to enable it again, but the Bluetooth continues without working.
If I run:
bluetoothctl
it gets stuck with the message:
Waiting to connect to bluetoothd
I have tried to enable the bluetooth using the RPI command:
systemctl start bluetooth
but systemctl is not available.
Any ideas? I have tried the solutions in this post Thank you very much
