hassOS 4.8 broke MQTT device, restoring snapshot doesnt solve issue
System working happily, then updated to 4.8 OS which broke it. Aprox three hardware reboots lates system came back up on 3.13 - but my kitchen lights wouldnt respond (switched on, but slider went back to off).
Tried restoring an older image, didnt solve the problem
Tried rebuilding new SD card & restoring from an older image, still not working.
Noticed other MQTT devices are working its just the kitchen ones. Any idea how to solve this? Let me know if you need other logs / info.
zigbee2mqtt log extract:
zigbee2mqtt:info  2020-06-04 17:00:00: MQTT publish: topic 'zigbee2mqtt/Bedside_Lamp_R', payload '{"state":"ON","linkquality":13,"brightness":25,"last_seen":1588713300774,"update_available":false}'
zigbee2mqtt:info  2020-06-04 17:00:01: MQTT publish: topic 'zigbee2mqtt/Bedside_Lamp_L', payload '{"state":"ON","linkquality":31,"brightness":25,"last_seen":1588713300802,"update_available":false}'
zigbee2mqtt:error 2020-06-04 17:00:10: Publish 'set' 'state' to 'Kitchen_Right' failed: 'Error: Command 0x000b57fffea899a0/1 genOnOff.on({}, {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error: Data request failed with error: 'No network route' (205))'
zigbee2mqtt:info  2020-06-04 17:00:10: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"zigbee_publish_error","message":"Publish 'set' 'state' to 'Kitchen_Right' failed: 'Error: Command 0x000b57fffea899a0/1 genOnOff.on({}, {\"timeout\":10000,\"manufacturerCode\":null,\"disableDefaultResponse\":false}) failed (Error: Data request failed with error: 'No network route' (205))'","meta":{"friendly_name":"Kitchen_Right"}}'
zigbee2mqtt:error 2020-06-04 17:00:11: Publish 'set' 'state' to 'Kitchen_Left' failed: 'Error: Command 0x90fd9ffffe1f3680/1 genOnOff.on({}, {"timeout":10000,"manufacturerCode":null,"disableDefaultResponse":false}) failed (Error: Data request failed with error: 'No network route' (205))'
zigbee2mqtt:info  2020-06-04 17:00:11: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"zigbee_publish_error","message":"Publish 'set' 'state' to 'Kitchen_Left' failed: 'Error: Command 0x90fd9ffffe1f3680/1 genOnOff.on({}, {\"timeout\":10000,\"manufacturerCode\":null,\"disableDefaultResponse\":false}) failed (Error: Data request failed with error: 'No network route' (205))'","meta":{"friendly_name":"Kitchen_Left"}}'
I have the same problem
“(Error: Data request failed with error: ‘No network route’ (205)”
did you manage sort the problem, if so please share the solution
