Has anyone had success installing HeyU or Mochad or something that controls X10 in HassOS in a Windows VirtualBox?
When I run Mochad, I get this error
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 197, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/mochad/light.py", line 39, in setup_platform
add_entities([MochadLight(hass, mochad_controller.ctrl, dev) for dev in devs])
File "/usr/src/homeassistant/homeassistant/components/mochad/light.py", line 39, in <listcomp>
File "/usr/src/homeassistant/homeassistant/components/mochad/light.py", line 55, in __init__
self._state = self._get_device_status()
File "/usr/src/homeassistant/homeassistant/components/mochad/light.py", line 66, in _get_device_status
status = self.light.get_status().rstrip()
File "/usr/local/lib/python3.8/site-packages/pymochad/device.py", line 55, in get_status
return self.controller.read_data().lower()
File "/usr/local/lib/python3.8/site-packages/pymochad/controller.py", line 83, in read_data
data = self.socket.recv(4096)
ConnectionRefusedError: [Errno 111] Connection refused
I have the port set at 1099. Is it possible I have the wrong port? How could I tell from terminal if I have the right port?
When I try to run HeyU I get
curl: (6) Could not resolve host: POST error.
From what I can tell, these errors have to do with port forwarding, but I’m operating on a bridged adapter. I’m not sure how to clear it so it goes through. My Z stick works, as does everything else of mine. I would just like to see if I can get X10 to work. Thanks.
