No idea why I’m getting this error, but I’m unable to update. I have plenty of available space on my SD card (21.2 GB free of 28.5 GB)
Raspberry Pi 3b
HassOS 4.10
The docker hub says it’s available… but I’m having ‘unknown error, see logs’ returned.
https://hub.docker.com/r/homeassistant/raspberrypi3-homeassistant/tags
Error log for reference:
20-06-24 00:21:18 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.111.4
20-06-24 00:21:18 INFO (SyncWorker_19) [supervisor.docker.interface] Update image homeassistant/raspberrypi3-homeassistant:0.111.0 to homeassistant/raspberrypi3-homeassistant:0.111.4
20-06-24 00:21:18 INFO (SyncWorker_19) [supervisor.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag 0.111.4.
20-06-24 00:21:20 ERROR (SyncWorker_19) [supervisor.docker.interface] Can’t install homeassistant/raspberrypi3-homeassistant:0.111.4 -> 404 Client Error: Not Found (“no such image: homeassistant/raspberrypi3-homeassistant:0.111.4: No such image: homeassistant/raspberrypi3-homeassistant:0.111.4”).
20-06-24 00:21:20 WARNING (MainThread) [supervisor.homeassistant] Update Home Assistant image fails
