I have a HP T630 and I want to disable the built in Bluetooth and Wifi. Through Ubuntu, it can be done, but after I installed HASSOS 14.1 I cannot find any way to do that. In my RPI time, I could remove the SDCard and edit the boot config.txt, but with this (for me) new system I cannot find the config.txt anymore.
Try to see if you can do it in BIOS instead.
I checked and as far as I can see, it cannot be disabled there.
I removed the board… easiest solution for me!
