I got the SSH keyless connection going and are logged in as root through SSH onto the machine.
However when i try the “docker” command it just says “command not found”
I read in a forum that you have to issue the “Login” command before you can actually do the commands. But when i do that i get prompted with username and password. And none of my existing works here.
I’m running HassOS 1.11
Version 140
Home Assistant
0.80.0
