Pi3B, Hassio 86.4. After OS reboot from web can’t connect to HA.
As I understand, docker can’t connect to hassos-network…
Have only loop messages:
… entered blocking state
… entered forwarding state
… entered disabled state
Help pls!!
NB: in \CONFIG\network\my-network set a static IP (with dhcp the same error):
[ipv4]
method=manual
address=192.168.1.102/24,192.168.1.1
dns=8.8.8.8;8.8.4.4;
Hi! As I understood it was docker image crash, because of the sd-card broken. Fixed by reinstall on a new card. It’s already 4-5 of my sd-card with similar problems. I’m finding a new device w/ flash, like VIM2.
Had the same problem. But SD card and filesystem is fine. Seem the docker container is broken. Anyone know a way to fix/upgrade the docker vom 3rd party system (or from recovery)?
Same here. Every time we have a power outage, the rPi3 won’t boot because the docker in stuck in a loop blocking then disable state. This is my 2nd SD card and rebuild again. And, I cannot SSH into either!
I just got this for the first time last night. I could not access the addons page or any of the addons web interfaces, but they all seemed to be working, at least Z2M did.
I run HAOS under a VM so the SD scenario does not fit.
Commenting just for visibility and maybe to attract attention.
