HassOS docker0: port1 entered disabled state
Pi3B, Hassio 86.4. After OS reboot from web can’t connect to HA.
As I understand, docker can’t connect to hassos-network…
Have only loop messages:
… entered blocking state
… entered forwarding state
… entered disabled state
Help pls!!
NB: in \CONFIG\network\my-network set a static IP (with dhcp the same error):
[ipv4]
method=manual
address=192.168.1.102/24,192.168.1.1
dns=8.8.8.8;8.8.4.4;
Update: looks like SD card issue. Closed.
What you mean with SD Card issue? How did you fix this? Had the same problem after the last update.
But for me this loops between docker0 and hassio.
Hi! As I understood it was docker image crash, because of the sd-card broken. Fixed by reinstall on a new card. It’s already 4-5 of my sd-card with similar problems. I’m finding a new device w/ flash, like VIM2.
Had the same problem. But SD card and filesystem is fine. Seem the docker container is broken. Anyone know a way to fix/upgrade the docker vom 3rd party system (or from recovery)?
Same here. Every time we have a power outage, the rPi3 won’t boot because the docker in stuck in a loop blocking then disable state. This is my 2nd SD card and rebuild again. And, I cannot SSH into either!
I use virtual machine Ubuntu and i have the same issue. Still can’t find a way to fix it.
No backup unfortunately.
have you fixed it?
Years later, did anyone ever fix? I’ve installed docker on so many things and always the same network problem.
