Connected to router via ethernet cable and the router supports DHCP
I followed the instructions to write the latest hassos_rpi4-4.10.img to a 64GB A2 SD card
I can’t get past the initial boot which continuously cycles through 5 steps:
A start job is running for Wait Until Kernal Time Synchronised
A start job is running for HassOS ZRAM tmp
A start job is running for HassOS ZRAM swap
A start job is running for HassOS data resizing
A start job is running for HassOS ZRAM var
I’ve attached relevant screenshots.
I don’t need a network configuration according to the instructions (happy to use DHCP via ethernet) but also tried with a network config on USB but made no difference.
Pretty sure I followed the instructions correctly, anyone able to advise what I missed?
For anyone else experiencing a similar issue, I have changed the title of this post as it has been confirmed that the 8GB model of RPI 4 is not currently supported:
Any chances this is close for a release?
I just received my Pi that I want to use just for HA.
I’ve tried temporarily putting it in a docker, not realizing that I cant run the supervised version this way, so I suppose I am back waiting for a release to be issued.
There is a pre-release of HassOS 5.0 available now. It supports RPI4 8 GB and USB-boot on RPI4 (only for the 64-bit version of the OS).
For USB-boot, read the documentation and make sure to update your PI4 with the latest eeprom firmware. 2020-07-16 firmware worked for perfectly for me at least!
hey!
im trying this myself, however i keep getting the Timeout waiting for hardware CMD interrupt message.
i did edit the config.txt file - however im not sure this is the correct place, as i was doing that on the RPI OS, which is on the MicroSD, that was removed, so i can boot from the SSD (which has v5 of HassOS)
what steps did you follow to do a clean boot of HassOS from an SSD?
New to HomeAssistant and bought the 8GB Raspberry Pi 4B.
Using the Pi OS I ran the boot loader update utility to grab the soon to be released version suggested by eric73 and updated the board. I then flashed the HA 4.11 version from the HomeAssistant web site and it is running fine.
edit ‘sudo nano /etc/default/rpi-eeprom-update’ and change from ‘critical’ to ‘beta’
$ sudo nano /etc/default/rpi-eeprom-update’
run and confirm you see the updated July version
$ sudo rpi-eeprom-update
CURRENT: Thu 16 Apr 17:11:26 UTC 2020 (1587057086)
LATEST: Thu 16 Jul 15:15:46 UTC 2020 (1594912546)
Install the updated EEPROM image and reboot
$ sudo rpi-eeprom-update -a
$ sudo reboot
Check it is installed
CURRENT: Thu 16 Jul 15:15:46 UTC 2020 (1594912546)
I then flashed the latest HomeAssistant image on the SD card and it worked as it should.
Any update on this? I tried the steps above from @sillygoose and it did indeed update to the latest eeprom (July 31 in my case), but when I try booting to HA it still just boots to the same screen as mentioned by the OP. I have tried HASSOS versions 4.12 and 5.1. Both had the same result.
