Hassos getting stuck during boot "waiting for root device PARTUUID=XXXX...."
HI, im trying to get HASSOS up and running on an old dell R710 i have spare here at my house before commiting to the ~500 it costs to get a intel NUC in my country.
I have followed the installation guide here @Generic x86-64 - Home Assistant
I have enabled UEFI boot and it appears to start booting, but gets stuck partway through and never progresses when stuck on the error in the title (xxx is some manufacturer ID of some part I believe)
I have tried re-flashing a few times, I tried booting from my local desktop PC but i couldn’t get it to work (just skipped and went straight to windows) although i think this is due to my BIOS settings are quite specific to get my NVME SSD to work properly on my older system.
I have read around abit but its not entirely clear, but is Hassos only supported for Raspberry Pi or intel NUCs? is it possible the hardware I am trying to use in incompatible? the instructions dont explicitly say NUC/RaPi only but seem to imply that NUCs/RaPi are are preferred?
cheers for any pointers
Faced the same problem. I installed the image on the SDD and connected via sata and everything worked.
Good morning!
Sorry to dig up this old thread, but (aside from the suggestion to replace the nvme with a sata ssd) there was never a conclusion to it.
I’m having the exact same problem. Tried with 3 different nvme disks and tried fiddling with the BIOS settings, but had no luck.
It’s an Asus laptop that I’m repurposing, because it’s cheap (I already have it) and lower power consumption when compared to a desktop machine.
So, @Crashbash2020 did you ever manage to solve your problem? How?
Thank you!
Yeah facing the same issue. I’m going the route of " Installing HAOS via Ubuntu booting from a USB flash drive"
Booted Ubuntu, followed instructions. Then try to reboot, and I get the same waiting for device message and then noting.
I try to run on a VM in hyper-v
Never mind me, there is a hyper-v image that just works.
thankyou for this GEM… I too am an idiot and was doing all the setup and then was getting the same error and then found this post… out loud in my lounge room “IM A GOD DAMN IDIOT”. My wife told me to shutup haha.
for prosperity https://github.com/home-assistant/operating-system/releases/download/15.0/haos_ova-15.0.vhdx.zip
I had this issue installing on my old Dell XPS
In the BIOS I had to disable RAID for the NVME drive
