IanRH
(Ian)
January 27, 2023, 7:24pm
62
I’ve never had ZHA installed, and can’t get it past this screen at the moment so it makes no logs that i can see? I looked through the HA logs and there was nothing obvious in there; am i looking in the right places though…
IanRH
(Ian)
January 27, 2023, 7:25pm
63
PS I salute your patience!
aceindy
(Aceindy)
January 27, 2023, 7:36pm
64
Don’t think I can offer much more help, never used ZHA
Maybe check-out Zigbee2mqtt?
At least you would know if it works
(PS, you’ll also need a mqtt-broker)
@mkanet
Promised I would get back to you once I moved my Zigbee2mqtt server from windows to HassOS using my Eltima virtual port over LAN.
How?
On Windows10:
CC2531 hardware is connected to USB (COM8)
Eltima setup as comport server on TCP port 5656, with settings com8, real port, 115200 baud ,No parity,8 data bits ,1 stop bit
On HassOS (running under Hyper-V on the same W10 machine)
Installed Zigbee2mqtt HassIO Add-on (from repository GitHub - zigbee2mqtt/hassio-zigbee2mqtt: Official Zigb…
IanRH
(Ian)
January 27, 2023, 7:47pm
65
Z2M is the b-plan yes. Looks like that might be where it ends up. Really appreciate the help, at least I know I got some of it right!
