Just installed the Home Assistant OS on my OdroidN2+. Followed the instructions as mentioned in ODROID - Home Assistant
File flash was finished without errors.
Power off
Switch to emmc startup
it won’t boot into the home assistant but gives repeating error : Can’t connect to the Docker daemon at unix…
Tried reïnstalling but no luck cause already software on emmc.
Want to find a solution.
