I am running HassOs in intel NUC. Inside I have a M.2 Nvme and an SSD.
Is there any way to use both drives?
With proper configuration you should be able to use the 2nd drive for the recorder DB and snapshots, allowing much better wear leveling and long term reliability of the primary drive
Thank you for your answer.
Can you please elaborate what do you mean by “proper configuration”? Xhere can I find some guidelines?
By changing the mount point of the configuration directory, using links, or both.
Changing the mount point allows the config dir for the OS to be on a different partition, or even on another drive. Setting a symlink for the db filename and linking that to a different partition on that drive reduces fragmentation. You can also use different filesystems, such as btrfs for the config mount and ext4 for the db mount, to make use of its snapshot features independently of the built in backup solution
