Hi, I’m a beginner to hassio and I’m wondering if hassio / hassos can be also used on a 32bit virtual machine. I have 2 embedded PC’s based on Intel Atom which are able to run 32 bit OS only.
Thank you for helping.
As far as I know there is no 32-bit images of Home Assistant One. So I believe the best bet is Supervised Install if you want to keep the add-on and UI updater.
It would solve the problem of needing to use Supervised install for me.
