Hassos on RPI4 - how find big files on system
My home_Assistant-v2.db is about 500 Mb, but hard disk is occupied for 9 GB
Which files occupied that space?
How can i find fbig fles to know what cause big space?
hi
try this
du -h --max-depth=1 /
if you want, replace / with some other path /etc/ or /config more and more
thanks a lot , but syntax might have changed I guessed cause HASSOS is unhappy with --max-depth
at least right now this one has worked for me where -d 1 replaces the --max-depth if I had understood the help right
du -h -d 1 /
