This morning I have upgraded home assistant from 0.110.4 to 0.111.0. When I did so, I noticed that HassOS could also be upgraded to 4.10. So after 0.111.0 was installed, and everything was running again (except for some custom lovelace cards), I pressed the update button on the HassOs.
And since then, my home assistant has been unavailable. I’ve even done a powercycle (“have you tried turning it off and on again?”).
Well, I’m back, thanks to the super efficient backup from @sabeechen (https://github.com/sabeechen/hassio-google-drive-backup, can reccommend).
No clue as to what went wrong, just had to start from scratch, by burning an image on an sd card…
Topic closed afaic…
I had to do a similar start from scratch. I pulled the most recent snapshot off the Pi’s sd card, burned a new sd card, and then applied the snapshot. Nothing else seemed to work.
