i dowloaded the hasspbian image flashed it and booted the PI with ethernet attached.
After the first boot, it looks like the setup script does not run. there is no /home/homeassistant hiden conf folder and the web interface does not run.
here is the log of pip
it looks like if the rasPI dont get an ip fast enough it does not execute it
Downloading/unpacking homeassistant
Getting page https://pypi.python.org/simple/homeassistant/
Could not fetch URL xxx://pypi.python.org/simple/homeassistant/: connection error: (‘Connection aborted.’, gaierror(-2, ‘Name or service not known’))
Will skip URL hxxs://pypi.python.org/simple/homeassistant/ when looking for download links for homeassistant
Getting page httxxps://pypi.python.org/simple/
Could not fetch URL htxxtps://pypi.python.org/simple/: connection error: (‘Connection aborted.’, gaierror(-2, ‘Name or service not known’))
Will skip URL htxxps://pypi.python.org/simple/ when looking for download links for homeassistant
Cannot fetch index base URL httxxps://pypi.python.org/simple/
URLs to search for versions for homeassistant:
httxxxps://pypi.python.org/simple/homeassistant/
Getting page hxxtps://pypi.python.org/simple/homeassistant/
Could not fetch URL xxtps://pypi.python.org/simple/homeassistant/: connection error: (‘Connection aborted.’, gaierror(-2, ‘Name or service not known’))
Will skip URL xxtps://pypi.python.org/simple/homeassistant/ when looking for download links for homeassistant
Could not find any downloads that satisfy the requirement homeassistant
Cleaning up…
No distributions at all found for homeassistant
Exception information:
File “/srv/homeassistant/lib/python3.4/site-packages/pip/basecommand.py”, line 122, in main
status = self.run(options, args)
File “/srv/homeassistant/lib/python3.4/site-packages/pip/commands/install.py”, line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File “/srv/homeassistant/lib/python3.4/site-packages/pip/req.py”, line 1178, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File “/srv/homeassistant/lib/python3.4/site-packages/pip/index.py”, line 277, in find_requirement
raise DistributionNotFound(‘No distributions at all found for %s’ % req)
pip.exceptions.DistributionNotFound: No distributions at all found for homeassistant
I guess the delay i get from DHCP is the problem. the systemd install script should have something like that, to wait for the network interface to be up before executing
