HASSWP decision
What are the downside of using HASSWP as my main instance? I’ve read you don’t have access to supervisor, but not sure what that means beyond sending log info back to HASS central… Any help is appreciated.
I have an older Win10 machine and trying to decide which way to install HASS.
Did you search & read their README?
Attention: Direct works in Windows is not tested by the core developers of Home Assistant. So some components/integrations may not work at all
from GitHub - AlexxIT/HassWP: Portable version of Home Assistant for Windows (no need to install)
I would not expect much of any support from this forum either since very few, if any, other users are running this.
Good point… thanks. The guys using it only spoke about the supervisor function not working…
You should be able to put VirtualBox on the Windows machine and run Home Assiatnt.
I think there is a HaOS image or you could run any of the Linux installation options.
I’m not going the HASSWP route, thanks for the feedback…
Is it OK to run a dual boot of Windows with HASS?
Thanks again.
Tom
I do not think there is a bootable HASS (now HaOS) image for an x86-64 computer. THE HA page says you can install HA Core with WSL but I do not recommend that option. Virtual Box is not too difficult. After creating the VM, set the Network Card to Bridged Mode and the VM will get a network address on your home network.
What you could do is
  1. backup windows
  2. Install proxmox
  3. Install haos and windows in proxmox containers
  4. profit
I am starting with HASSWP for learning about it as intall is extremely fast/easy with reduced overhead of learning about virtual boxes. The documentation is so utterly appalling compared to MrHouse I want the familiar Windows tools available for delving into it. Be warned the video linked on Github however does NOT show what actually boots up.
Would running it in a virtual box slow it down too much on an old machine?
As for ‘support’ on the forum, unfortunately so much of it is written in Geek it often falls short anyway for non computer whizz kids.
Pleased to meet you too.
