[{"id":"6bd66ba2.51fa34","type":"tab","label":"Camera Disable when home","disabled":false,"info":""},{"id":"74b4bb40.747bc4","type":"comment","z":"6bd66ba2.51fa34","name":"Flow Description","info":"Camera battery saver\n\nIf either of us are home, set the profile on the pool and dog yard cameras to conserve battery. \n\nIf either of us are away, set the profile to away mode, which is for maximum security. \n\nIf either of us are home, but it's after dusk and before sunrise is complete, set the profile to away mode, which is for maximum security.\n\n","x":880,"y":680,"wires":[]},{"id":"f87f8aa6.1eb058","type":"bigtimer","z":"6bd66ba2.51fa34","outtopic":"arlocams","outpayload1":"on","outpayload2":"off","name":"It's Daytime","comment":"","lat":"33.89654","lon":"-117.30287","starttime":"5003","endtime":"5001","starttime2":0,"endtime2":0,"startoff":"30","endoff":0,"startoff2":0,"endoff2":0,"offs":0,"outtext1":"Arlo set to Home","outtext2":"Arlo set to Away","timeout":1440,"sun":true,"mon":true,"tue":true,"wed":true,"thu":true,"fri":true,"sat":true,"jan":true,"feb":true,"mar":true,"apr":true,"may":true,"jun":true,"jul":true,"aug":true,"sep":true,"oct":true,"nov":true,"dec":true,"day1":0,"month1":0,"day2":0,"month2":0,"day3":0,"month3":0,"day4":0,"month4":0,"day5":0,"month5":0,"day6":0,"month6":0,"day7":0,"month7":0,"day8":0,"month8":0,"day9":0,"month9":0,"day10":0,"month10":0,"day11":0,"month11":0,"day12":0,"month12":0,"d1":0,"w1":0,"d2":0,"w2":0,"d3":0,"w3":0,"d4":0,"w4":0,"d5":0,"w5":0,"d6":0,"w6":0,"xday1":0,"xmonth1":0,"xday2":0,"xmonth2":0,"xday3":0,"xmonth3":0,"xday4":0,"xmonth4":0,"xday5":0,"xmonth5":0,"xday6":0,"xmonth6":0,"xd1":0,"xw1":0,"xd2":0,"xw2":0,"xd3":0,"xw3":0,"xd4":0,"xw4":0,"xd5":0,"xw5":0,"xd6":0,"xw6":0,"suspend":false,"random":false,"repeat":true,"atstart":true,"odd":false,"even":false,"x":370,"y":380,"wires":[["3668004.afa1f"],[],[]]},{"id":"6c531352.5349cc","type":"api-current-state","z":"6bd66ba2.51fa34","name":"Nikki Away","server":"84a8d823.e15248","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.nikki_home","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":750,"y":360,"wires":[["541f3fc6.d5a4f"],[]]},{"id":"3a62972f.24db48","type":"api-current-state","z":"6bd66ba2.51fa34","name":"Matthew Away","server":"84a8d823.e15248","version":1,"outputs":2,"halt_if":"off","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.matthew_home","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":760,"y":520,"wires":[["541f3fc6.d5a4f"],[]]},{"id":"e6f3c130.bdedd","type":"api-current-state","z":"6bd66ba2.51fa34","name":"Matthew Home?","server":"84a8d823.e15248","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.matthew_home","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":720,"y":300,"wires":[["aed7029b.bc479"],["6c531352.5349cc"]]},{"id":"f35a7882.3e20f8","type":"api-current-state","z":"6bd66ba2.51fa34","name":"Nikki Home?","server":"84a8d823.e15248","version":1,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_boolean.nikki_home","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":710,"y":460,"wires":[["aed7029b.bc479"],["3a62972f.24db48"]]},{"id":"aed7029b.bc479","type":"api-call-service","z":"6bd66ba2.51fa34","name":"Set Arlo to HOME","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"alarm_control_panel","service":"alarm_arm_home","entityId":"alarm_control_panel.aarlo_arlo_pro_2_base_station","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1030,"y":340,"wires":[[]]},{"id":"541f3fc6.d5a4f","type":"api-call-service","z":"6bd66ba2.51fa34","name":"Set Arlo to ARMED","server":"84a8d823.e15248","version":1,"debugenabled":false,"service_domain":"alarm_control_panel","service":"alarm_arm_away","entityId":"alarm_control_panel.aarlo_arlo_pro_2_base_station","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1030,"y":440,"wires":[[]]},{"id":"e88756d1.a07338","type":"inject","z":"6bd66ba2.51fa34","name":"","topic":"","payload":"on","payloadType":"str","repeat":"","crontab":"*/1 0-5 * * *","once":false,"onceDelay":0.1,"x":210,"y":340,"wires":[["f87f8aa6.1eb058"]]},{"id":"7bb70308.fdb90c","type":"inject","z":"6bd66ba2.51fa34","name":"","topic":"","payload":"off","payloadType":"str","repeat":"","crontab":"*/1 0-5 * * *","once":false,"onceDelay":0.1,"x":210,"y":380,"wires":[["f87f8aa6.1eb058"]]},{"id":"cd02aebc.98631","type":"inject","z":"6bd66ba2.51fa34","name":"","topic":"","payload":"auto","payloadType":"str","repeat":"","crontab":"*/1 0-5 * * *","once":false,"onceDelay":0.1,"x":210,"y":420,"wires":[["f87f8aa6.1eb058"]]},{"id":"3668004.afa1f","type":"switch","z":"6bd66ba2.51fa34","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"on","vt":"str"},{"t":"eq","v":"off","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":530,"y":380,"wires":[["e6f3c130.bdedd","f35a7882.3e20f8"],["541f3fc6.d5a4f"]]},{"id":"84a8d823.e15248","type":"server","z":"","name":"Home Assistant"}]
I know bigtimer updates every one minute, so it leads me to believe the problem is there, but since it’s in the correct state during this time window, I’m assuming it’s not switching on/off. I’ve added a debug on it for tonight in the interim.
I’m using bigtimer in another flow, as well. On the other flow I do have bigtimer to check temperature and fan speed between 0000 - sunrise. Sunrise happens to be 0548. Could this be the issue? Is bigtimer conflicting with itself on different flows?
I know that I’m still just talking to myself here, but I also changed the above flow to not use bigtimer. Instead, I configured the poll state node to poll every 60 seconds to see if the fan is on. Then I used the time range node to only evaluate during midnight and sunriseEnd. I don’t like using it this way because now the poll state node is checking every minute for 24 hours instead of only checking every minute for ~6 hours.
I am a dumbass. my inject nodes that are there to manually control bigtimer were configured to inject every minute between 0000 - 0600.
