So to get a couple of things out of the way…
HA version - 2024.5.3
Supervisor - 2024.05.1
Running bare metal install on Dell i5 micro system.
I have a fairly complex automation that controls lighting in our bathroom during various intervals of day and night and involves a motion detector. We have dogs and at night it is really dark getting from the dog crates to the front door, so I have deployed a Xiaomi button that I wish to override the motion detector with to activate many of the same lights plus a couple more. I would like to click the button to turn on the lights and then click again to turn them back off.
The problem is that if I get in range of the motion sensor it fires a motion event and due to the nature of the the Xiaomi button retaining the last click type state an event to shut off lights is triggered and should not be. I can see 2 possible ways to make it work. 1) not allow the motion sensor to trigger some how during the late night hours and only run with the button as a trigger. I am really not sure how to accomplish this option. 2) within the subsection of my automatin that takes the click input to turn on the lights have a sequence call that changes the “last click” event to something other than “single”, another thing that I am not sure how to do. I have figured out if I single click and the follow up with a double click that triggers nothing that the motion sensor trigger then does not cause the failure state, so I think option 2 may be the way to go.
I am including the whole automation and then will break out the relevant sections that are causing the problem. Fair warning… I am not the best automation writer and my format may be not the most efficient.
I have not imported this automation into the automation editor as it appears that comments contained within the automation are lost and I do not appear to be able to put them back in and have them visible? Is this something I am doing wrong?
Full automation:
- id: Bathroom_motion
alias: Bathroom motion
- platform: state
entity_id: binary_sensor.motion_sensor_158d0001644ca3
- 'off'
to:
- 'on'
- platform: event
event_type: xiaomi_aqara.click
event_data:
entity_id: binary_sensor.switch_158d0001e5f29e
click_type: "single"
- platform: event
event_data:
click_type: "hold"
mode: queued
max: 20
- choose:
- conditions:
########## Motion to turn on lights during daytime ##########
- condition: template
value_template: "{{ trigger.to_state.state == 'on' }}"
- condition: time
after: '06:00:00'
before: '20:30:00'
- condition: state
entity_id: timer.bathroom_motion_short
state: 'idle'
- condition: state
entity_id: timer.bathroom_motion_long
state: 'idle'
- condition: state
entity_id: input_boolean.notify_bathroom_tag
state: "off"
sequence:
- service: light.turn_on
entity_id: group.bathroom_lights
brightness: 254
kelvin: 5000
- service: timer.start
- conditions:
########## Motion to turn on lights early night 4000k ##########
- condition: time
after: '20:30:00'
before: '23:00:00'
- condition: state
state: 'idle'
- condition: state
state: "off"
- condition: state
entity_id: input_boolean.night_dog
state: "off"
sequence:
brightness: 254
kelvin: 4000
- conditions:
########## Motion to turn on lights night 3750k ##########
- condition: state
entity_id: timer.bathroom_heat_tag
state: 'idle'
- condition: state
state: 'off'
- condition: time
after: '23:00:00'
before: '06:00:00'
- condition: state
state: "off"
sequence:
entity_id: light.bathroom_1,light.toolbox,light.sink,light.tree_top
brightness: 15
kelvin: 3750
entity_id: light.computer_lamp
brightness: 10
kelvin: 3750
########## 1 click to turn off lights at night ##########
- conditions:
# - condition: state
# entity_id: timer.bathroom_motion_short
# state: 'idle'
# entity_id: timer.bathroom_motion_long
# state: 'active'
- condition: state
attribute: last_action
state: single
- condition: time
after: '23:00:00'
before: '06:00:00'
- condition: state
state: "off"
- condition: state
state: "on"
sequence:
- service: timer.finish
- service: input_boolean.turn_off
- service: light.turn_off
entity_id: light.door,light.computer_lamp,light.tree_top,light.sink,light.toolbox
########## 1 click to turn on lights at night ##########
- conditions:
# state: 'idle'
# state: 'idle'
- condition: time
after: '23:00:00'
before: '06:00:00'
- condition: state
state: single
- condition: state
state: "off"
- condition: state
state: "off"
sequence:
entity_id: light.bathroom_1,light.toolbox,light.sink,light.tree_top,light.computer_lamp
brightness: 15
kelvin: 3000
# - service: timer.start
brightness: 254
########## Hold to toggle lights at night ##########
# - conditions:
# entity_id: binary_sensor.switch_158d0001e5f29e
# attribute: last_action
# state: hold
# - condition: time
# after: '22:30:00'
# before: '06:00:00'
# sequence:
# - service: light.toggle
# entity_id: light.door
- id: Bathroom_long_timer_expired
alias: Bathroom long timer expired
- platform: event
event_type: timer.finished
event_data:
condition:
condition: template
value_template: >
{{ not is_state('timer.bathroom_heat_tag','active') }}
entity_id: group.bathroom_lights,light.door
- id: Bathroom_short_timer_expired
alias: Bathroom short timer expired
- platform: event
event_data:
- choose:
- conditions:
- condition: time
after: '06:00:00'
before: '23:00:00'
value_template: >
sequence:
- conditions:
- condition: time
after: '23:00:00'
before: '06:00:00'
value_template: >
sequence:
entity_id: group.bathroom_lights,light.tree_top,light.sink,light.computer_lamp
Sections that are causing the problem:
Lights turning on with click:
- conditions:
# state: 'idle'
# state: 'idle'
- condition: time
after: '23:00:00'
before: '06:00:00'
- condition: state
state: single
- condition: state
state: "off"
- condition: state
state: "off"
sequence:
brightness: 15
kelvin: 3000
brightness: 254
Lights turning off with click and being screwed up by the “last action” state of the button and motion activation as a main trigger.
- conditions:
# state: 'idle'
# state: 'active'
- condition: state
state: single
- condition: time
after: '23:00:00'
before: '06:00:00'
- condition: state
state: "off"
- condition: state
state: "on"
sequence:
The timer finish in the above kills the lights in the bathroom that may have been triggered by the motion sensor and then the lights that are triggered by the button press are turned off as well.
I am really hoping that someone will see something that I have overlooked… I have been beating my head for way to long to attempt to figure this little but out in this automation. I have left test code in place commented out as well.
Thanks Matt
