I’m seeing a warning on startup from MQTT about the schema option being deprecated :
[homeassistant.components.mqtt] The ‘schema’ option is deprecated, please remove it from your configuration
Trouble is I can’t find it anywhere in my config. What am I missing ?
tom_l
March 22, 2024, 12:14pm
2
Do you use Valetudo?
That is what is generating this warning for me.
The dev will release an update eventually.
opened 10:03AM - 03 Feb 24 UTC
closed 01:22PM - 09 Feb 24 UTC
Deprecation warnings in Home Assistant logs at startup concerning set up of mqtt… .vacuum
In fact, this is not a bug in Valetudo, just a change to how Home Assistant works. It's purely cosmetic, and the vacuums continue to work normally in HA (I have three). Sample log message:
Logger: homeassistant.components.mqtt.vacuum
Source: helpers/config_validation.py:917
Integration: MQTT (documentation, issues)
First occurred: 2 February 2024 at 20:54:42 (3 occurrences)
Last logged: 2 February 2024 at 20:54:42
The 'schema' option is deprecated, please remove it from your configuration
Related PR is here:
[https://github.com/home-assistant/core/pull/107274](url)
### To Reproduce
Steps to reproduce the behavior:
1. Start or restart Home Assistant
### Vacuum Model
Roborock S5 (x2)
Dreame L10 Pro
### Valetudo Version
2023.12.0
