Have no username or password. How to login?
I have come into possession of a yellow device after a relative who passed away. I don’t know his username or password. Should the device just be scrapped, or is there a solution?
Hi welcome to the forum!
Aside from the advice of fleskefjes: if that device is personalized with dashboards, devices and automations, it does not make any sense in trying to use the current setup since you will get a lot of errors and there will be not much that works.
I would strongly advice you to start from scratch which most likely will be much easier: https://support.nabucasa.com/hc/en-us/categories/24734575925149-Home-Assistant-Yellow
Specifically, you probably want to factory reset it:
Hi thank yuo for your respons.
I have allredy made a reboot of the unit to empty all data. But i cant find anyway how to change the username.
A reboot alone won’t do it. You must follow the reset process above Chris posted and in the process it will let you create a user account and credentials.
Excuse a beginner but i don´t understand point 2:
Go to Settings>System
Where do i find it.
You don’t need 1. and 2.
Start at 3.
OK thanks, the process i going on.
Alternatively you can just run ha os datadisk wipe via the CLI through keyboard & monitor/serial.
Sorry this procedure did not help me. I can still not create a new user and password.
and just wipe it with thismethod, i think you are either doing sonething wtong in resetting - this will help you to make sure it is clearly resetted or not
just follow the CONSOLE ACCESS part with a keyboard
Oh, I forgot the os part in my command above. Sorry about that.
