Have sunset triggers stopped working again?
Automation trigger at sunset…nothing.
Core 2024.12.3
Just found an updated: 2024.12.4. Will try that.
Post the trigger please, working over here on both versions you listed
alias: Test Plugs on at Sunset
description: ""
triggers:
  - trigger: sun
    event: sunset
    offset: 0
conditions: []
actions:
  - action: switch.turn_on
    metadata: {}
    data: {}
      entity_id:
        - switch.10017ff559_1
        - switch.10017fdb6a_1
        - switch.10017fdb57_1
        - switch.1001800716_1
mode: single
Can you check the automation trace and verify it did not run?
Moved out of WTH since this doesn’t at all appear to be a WTH
I’ll have to wait until tonight. I deleted the non-working automation and made this one, exactly as before. I hasn’t run yet.
But thanks for your attention.
My sunset activation trace shows it activated at 6:42 am this morning. Strange. I’ve checked my time zone is correct.
Are you in a VM? Is 6:42am the correct time (seems unlikely)?
You have a trace, so it’s running the automation.
Are you sure the entities you’re turning on/off still work?
No VM.
I noticed shortly after 6:42am that the switches had turned so that must be correct.
I can manually activate each switch, so that part is working.
What are you general settings set to? Specifically elevation
EDIT: I just noticed you said Core. So you’re only running HA core?
And you’re sure that the current location of Home is correct?
  • Core2024.12.4
  • Supervisor2024.12.0
  • Operating System14.0
  • Frontend20241127.8
Duh. You prompted me to check location; still set at Amsterdam! I’m assuming this will sort it out for me. (so, sunrise/sunset is by location, not time zone. Didn’t know that.)
Thanks for your guidance.
