This is my Lambda I have so far and need some help with.
on_value:
then:
lambda: |-
auto call = id(LED0).turn_on();
if ((id(ads1115_A0).state >= 1.771) && (id(ads1115_A0).state < 4.00)) {
call.set_brightness(.6);
call.set_rgb(1.00,0.00,0.00);
} else if ((id(ads1115_A0).state >= 1.311) && (id(ads1115_A0).state < 1.771)) {
call.set_rgb(0.5,0.5,0.0);
} else
((id(ads1115_A0).state >= 0.400) && (id(ads1115_A0).state < 1.310)); {
call.set_rgb(0.0,1.0,0.0);
call.perform();
It’s only turns the led to one color. Green. No matter the value of the sensor. I was hoping for traffic light colors depending on the sensor state value.
Log snips:
[23:55:22][D][ads1115:163]: 'ADS1115 49 Channel A3-GND': Got Voltage=3.148313V
[23:55:24][D][api.connection:630]: Client 'Home Assistant 2021.6.6 (192.168.0.89)' connected successfully!
[23:55:27][D][ads1115:163]: 'ADS1115 48 Channel A1-GND': Got Voltage=1.732687V
[23:55:28][D][ads1115:163]: 'ADS1115 49 Channel A1-GND': Got Voltage=0.609563V
[23:55:30][D][ads1115:163]: 'ADS1115 48 Channel A0-GND': Got Voltage=2.968125V
[23:55:30][D][light:275]: '48-A0 indicator led' Setting:
[23:55:30][D][light:288]: Brightness: 60%
[23:55:30][D][light:297]: Red=0%, Green=100%, Blue=0%
[23:55:30][D][light:314]: Transition Length: 1.0s
[23:55:30][D][ads1115:163]: 'ADS1115 49 Channel A0-GND': Got Voltage=1.515375V
[23:55:30][D][ads1115:163]: 'ADS1115 48 Channel A2-GND': Got Voltage=0.639375V
[23:55:33][D][ads1115:163]: 'ADS1115 48 Channel A3-GND': Got Voltage=0.616687V
[23:50:05][D][ads1115:163]: 'ADS1115 49 Channel A0-GND': Got Voltage=1.483125V
[23:50:06][D][ads1115:163]: 'ADS1115 48 Channel A0-GND': Got Voltage=1.479938V
[23:50:06][D][light:275]: '48-A0 indicator led' Setting:
[23:50:06][D][light:288]: Brightness: 60%
[23:50:06][D][light:297]: Red=0%, Green=100%, Blue=0%
[23:50:06][D][light:314]: Transition Length: 1.0s
[23:50:08][D][sensor:117]: '49-A0 Soil Saturation': Sending state 62.32372 % with 0 decimals of accuracy
[23:50:08][D][sensor:117]: '48-A1 Soil Saturation': Sending state 8.21313 % with 0 decimals of accuracy
[23:50:19][D][sensor:117]: '48-A2 Soil Saturation': Sending state 100.00000 % with 0 decimals of accuracy
This is for a soil sensor project I’m working on that will have 16 soil sensors with one WS2812 led for each sensor
Full working code as of now. Just not fully fleshed out:
esphome:
platform: ESP8266
board: d1_mini_lite
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "ggg"
wifi:
ssid: "ggg"
password: "ggg"
ap:
ssid: "Soil-Water-Level"
password: "ggg"
captive_portal:
i2c:
sda: D2
scl: D1
scan: True
ads1115:
# i2c_id: bus_a
- address: 0x48
- address: 0x49
#for esp32 only
#ads1115:
# i2c_id: bus_b
# address: 0x49
# id: ads1115_49
# ads1115-48 A0
- platform: ads1115
multiplexer: 'A0_GND'
gain: 6.144
name: "ADS1115 48 Channel A0-GND"
ads1115_id: ads1115_48
update_interval: 30s
internal: true
# 1.771 soil from holding bin placed in a cup (Dry)
# 1.310 soil in a cup with lotof water (Wet)
#on_raw_value:
on_value:
then:
lambda: |-
} else
call.perform();
filters:
- sliding_window_moving_average: # averages the last 5 results,
window_size: 5
send_every: 5
- lambda: |-
if (x > 1.771) {
return 0;
} else if (x < 1.310) {
return 100;
} else {
return (1.771-x) / (1.771-1.310) * 100.0;
name: "48-A0 Soil Saturation"
unit_of_measurement: "%"
icon: "mdi:water-percent"
accuracy_decimals: 0
lambda: |-
return id(ads1115_A0).state;
# ads1115-48 A1
- platform: ads1115
multiplexer: 'A1_GND'
gain: 6.144
name: "ADS1115 48 Channel A1-GND"
internal: true # Don't expose sensor to hass, the template sensors does that
filters:
window_size: 5
send_every: 5
- lambda: |-
if (x > 1.771) { // if over 1.771 volts, dry enough to water
return 0;
} else if (x < 1.310) { // if under 1.310 volts, we are sokeing wet
return 100;
} else {
return (1.771-x) / (1.771-1.310) * 100.0; // linear for any values in between
name: "48-A1 Soil Saturation"
lambda: |-
return id(ads1115_A1).state;
# ads1115-48 A2
- platform: ads1115
multiplexer: 'A2_GND'
gain: 6.144
name: "ADS1115 48 Channel A2-GND"
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "48-A2 Soil Saturation"
lambda: |-
return id(ads1115_A2).state;
# ads1115-48 A3
- platform: ads1115
multiplexer: 'A3_GND'
gain: 6.144
name: "ADS1115 48 Channel A3-GND"
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "48-A3 Soil Saturation"
lambda: |-
return id(ads1115_A3).state;
# ads1115-49 A0
- platform: ads1115
gain: 6.144
name: "ADS1115 49 Channel A0-GND"
ads1115_id: ads1115_49
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "49-A0 Soil Saturation"
lambda: |-
return id(ads1115_B0).state;
# ads1115-49 A1
- platform: ads1115
gain: 6.144
name: "ADS1115 49 Channel A1-GND"
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "49-A1 Soil Saturation"
lambda: |-
return id(ads1115_B1).state;
# ads1115-49 A2
- platform: ads1115
gain: 6.144
name: "ADS1115 49 Channel A2-GND"
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "49-A2 Soil Saturation"
lambda: |-
return id(ads1115_B2).state;
# ads1115-49 A3
- platform: ads1115
gain: 6.144
name: "ADS1115 49 Channel A3-GND"
filters:
window_size: 5
send_every: 5
- lambda: |-
return 0;
return 100;
} else {
name: "49-A3 Soil Saturation"
lambda: |-
return id(ads1115_B3).state;
light:
- platform: neopixelbus
type: GRB
pin: GPIO3
num_leds: 9
internal: true
- platform: partition
name: "48-A0 indicator led"
internal: true
segments:
- id: indicatorlt
to: 0
name: "48-A1 indicator led"
internal: true
segments:
- id: indicatorlt
to: 1
name: "48-A2 indicator led"
internal: true
segments:
- id: indicatorlt
to: 2
name: "48-A3 indicator led"
internal: true
segments:
- id: indicatorlt
to: 3
name: "49-A0 indicator led"
internal: true
segments:
- id: indicatorlt
to: 4
name: "49-A1 indicator led"
internal: true
segments:
- id: indicatorlt
to: 5
name: "49-A2 indicator led"
internal: true
segments:
- id: indicatorlt
to: 6
name: "49-A3 indicator led"
internal: true
segments:
- id: indicatorlt
to: 7
#internal: true , Left avbl to HA to test leds
segments:
- id: indicatorlt
to: 8
