’m stumped. I haven’t been able to apply the past couple of core updates on my HA instance. It’s in a VM on my Synology NAS. Has been running over a year with minimal issues until now. I get the following error from the supervisor log:
2024-07-11 06:34:01.245 ERROR (MainThread) [supervisor.docker.interface] Can’t install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.2: 404 Client Error for http+docker://localhost/v1.45/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.2/json: Not Found (“No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.2”)
And errors like this in the Host log:
2024-07-11 13:33:38.612 homeassistant dockerd[529]: time=“2024-07-11T13:33:38.612380527Z” level=info msg=“Download failed, retrying (4/5): local error: tls: bad record MAC”
2024-07-11 13:34:00.846 homeassistant dockerd[529]: time=“2024-07-11T13:34:00.846070931Z” level=info msg=“Attempting next endpoint for pull after error: local error: tls: bad record MAC” spanID=f9c4d0151ee2faef traceID=c194c22b429668894c5c748c2c558d71
I initially thought it was because the virtual disk was nearly full, but expanding the volume didn’t help. I also refreshed the virtual MAC address in the VM. No luck. I also spun up a new VM and restored a backup. Still can’t update. Any troubleshooting steps?
