Managed to find the time to have a look at this, sorry for taking so long!
Output from Smartbox:
$smartbox devices
[ { 'dev_id': '<dev_id>',
'fw_version': '1.25.0',
'name': '<housename>',
'product_id': '0105',
'serial_id': '14'}]
$smartbox nodes
<housename> (dev_id: <dev_id>)
[ { 'addr': 2,
'installed': True,
'level': 1,
'lost': False,
'name': 'LR.3.2',
'parent': 1,
'type': 'htr_mod'},
$smartbox setup
LR.3.2 (addr: 2)
{'power': '750', 'priority': 'low'}
$smartbox status
LR.3.2 (addr: 2)
{ 'active': False,
'comfort_temp': '19',
'eco_offset': '6',
'ice_temp': '7',
'locked': False,
'mode': 'manual',
'mtemp': '18',
'on': False,
'presence': False,
'selected_temp': 'comfort',
'sync_status': 'ok',
'uart_error': False,
'unit_fw': 2,
'unit_model': 2,
'units': 'C'}
And the JSON requests in the POST that are sent from the webUI
#on/off
{"on":true}
{"on":false}
#comfort temperature
{"mode":"manual","selected_temp":"comfort"}
#eco temperature
{"mode":"manual","selected_temp":"eco"}
#anti frost temperature
{"mode":"manual","selected_temp":"ice"}
#mode self learn (based on presence
{"mode":"self_learn"}
#mode presence detection
{"mode":"presence"}
#mode auto - based on calendar
{"mode":"auto"}
#change temp from 19 to 20
{"mode":"manual","comfort_temp":"20","eco_offset":"6","selected_temp":"comfort","on":true,"units":"C"}
#lock
{"locked":true}
{"locked":false}
Using smartbox, I can change between auto
, self-learn
and presence
fine. I can also lock ok. I can’t change to manual mode (returning a Bad Request
), which I presume is because the request does not contain the extra data (temperature etc) as requested. Also I don’t think the different selected_temp
options are handled for other devices?
If there’s anything else you need, just let me know - I’ll try and get back to you sooner this time!
