Having a hard time with Assistant Relay and automation
Hello!
I have Assistant Relay working perfectly if I configure it through a button…for example, I tap a button and Assistant Relay sends the Google home a command to turn off my bedroom fan.
How can integrate that into an automation? For example, at 9pm have Assistant Relay send a command to turn off the same fan.
I have this as my action and it fails with a malformed message.
    - data:
        command: "turn off the bedroom fan"
        service: rest_command.assistant_relay
I’ve tried it numerous ways, all fails with malformed error.
Your indentation is off. Try this:
  ....whatever...
  - data:
See the example in the docs here: https://www.home-assistant.io/integrations/rest_command/#using-a-rest-command-as-an-action-in-an-automation
Your REST command would also need to include the command somewhere.
