Having a problem with the raspberry pi gpio component
i’m currently having a problem with the raspberry pi gpio component.
i have copied the example code for the configuration.yaml from the component page and pasted it.
when i reboot my raspberry pi and type its ip in my browser the browser says that he cant find the requested page.
so i’m thinking that their is a problem in my configuration file and it wont start home assistant.
hope someone knows how to solve this problem.
b.t.w i’m running home assistant on a raspberry pi 3.
kind regards dylan
Can you post the yaml here using the code blocks as stated above in the blue box. Can you also post the errors if any from the log file.
Impossible to diagnose without at least some information :wink:
Thank you for replying
Here is my log file :
2017-06-04 14:17:36 ERROR (Thread-1) [homeassistant.util.yaml] duplicate key: “switch”
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 49, column 0
in “/home/homeassistant/.homeassistant/configuration.yaml”, line 55, column 0
2017-06-04 14:17:36 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: duplicate key: “switch”
Here is my configuration.yaml file :
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 51.6456
  longitude: 4.9063
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 2
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: Europe/Amsterdam
# Show links to resources in log and frontend
#introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Uncomment this to add a password (recommended!)
  # api_password: PASSWORD
  # Uncomment this if you are using SSL or running in Docker etc
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time.
history:
# View all events in a logbook
logbook:
# fritz dect outlets
switch:
  - platform: fritzdect
    username: Admin
    password: mypassword
# Raspberry pi GPIO control                                  <---- !!!! This is where i got the errors !!!! ---->
switch:
  - platform: rpi_gpio
    ports:
      18: Fan Office
      17: Light Desk
# Track the sun
sun:
# Example configuration.yaml entry
binary_sensor:
  - platform: iss
# Security Camera
camera:
  - platform: synology
    url: http://192.168.178.21:5000
    username: admin
    verify_ssl: False
# CPU Speed Component
  platform: cpuspeed
device_tracker:
  - platform: ping
    hosts:
      FritzBox: 192.168.178.1
media_player:
  - platform: braviatv
    host: 192.168.178.79
# Text to speech
tts:
  platform: google
#sensor:
#  - platform: random
group: !include groups.yaml
Get rid of the second switch.
Note that the error log says there is a duplicat key switch.
I’m guessing your “switch” is on line 49 and 55 also based on the error log.
ok thank you
so if i would want to use them both could i just put 2 platforms under one switch like this :
switch:
    username: Admin
    ports:
      18: Fan Office
      17: Light Desk
i figured the rest of the problem out on my own thank you for helping silvrr and keithh666
